GPU Sag with Zotac GTX 1070 AMP! Extreme?
pcfreaky
182
Hi everyone,
I am planning on ordering a Zotac GTX 1070 AMP! Extreme.
But for some reason my GPU Support bracket does not reach for the card.....
Is it going to be a problem using the gpu without a support bracket?
Pic:
https://gyazo.com/f013857f0ec72351b459f01bea215d5b
Currently I have the Asus GTX 660. Am I doing something wrong? Because this is the only place I can screw the support bracket on.
PC Case:
AZZA GT 1
You shouldn't have to worry about sagging very much. I have the Zotac AMP! (non-extreme). As long as it's secured properly on the rear IO with the thumb screws it should be able to support itself fine in your case without issue.
Side note: the card will require two 6+2 PCI power connectors so make sure your PSU has enough connectors as well.
Well, I already ordered the Corsair Vengeance 650W. And from the popularity and quality of that PSU it must have all the connectors needed for modern hardware. I guess..
