GPU Temperature help
RokyFrane
123
CPU: i5 6600k
GPU: ASUS R9 270 Direct CU II OC 2 GB
RAM: 16GB
PSU: 500W
COOLER: Cooler master hyper TX3 EVO
so the problem is.. my cpu temps are really good 52C in game max but GPU idle is 58-60C, in game is going from 85 to 91C.
Why am i getting that high temps? maybe hot weather outside? idk. My GPU fan is on auto and i dont know what is happening?
Maybe gpu temps in game from 85 to 92 is fine on this gpu.
While your card can run safely at those temperatures, I would be worried if my idle temp was 58-60C unless your ambient temperature in the room is also high. My card runs at 65C under 100% load and I don't have any specialised cooling.
As inerax said, your card will run fine at those temperatures. Personally I think the temperature is way too high unless you have it overclocked or the background temperature in your room is also high.
