[SOLVED] GPU Tweak 3 - Power target won't go above 105% ?!
MoeNAGY
BANNED
Apr 12, 2021
67
Good morning,
As the title says, I'm using GPU TWEAK 3 , I'm able to increase the GPU core clock and memory clock both by +140 MHz (stable) .. higher than that my games start crashing.
Thing I'm confused with is that in online video I see people able to raise there power target up to 125% .. My max power target on the slider is 105%, why is that?! why can't I go higher, up to 125%?
full system spec? include brand and model of the psu
PSU NZXT C850 ATX Gaming Power Supply / NP-C850M-US
Memory 32 GB - 2X (CORSAIR 16GB DDR4-3200 VENGEANCE RGB MEMORY )
Processor Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Motherboard Micro-Star International Co., Ltd. - MAG Z390 TOMAHAWK (MS-7B18)
Video Card
GIGABYTE - NVIDIA GeForce RTX 3090 VISION 24G GDDR6
Cooling CYBERPOWERPC DEEPCOOL CASTLE 360EX ARGB AIO LIQUID
Hard Drives 1TB ADATA XPG ASX6000LNP-1TT-C PCIE NVME M.2 SSD
240GB WD GREEN SSD 2.5" SATAIII 6.0 GB/s
3TB HDD 3.5" SATAIII 7200RPM 6.0 GB/s 64MB CACHE
The first thing to note are tweaks like these are suggestions for the GPU to take, not absolute orders. The GPU won't go to 125% because you told it to, it's merely "it's okay to go up to 125% if you think so"
As far as your issue goes though and because you didn't mention, this looks more like you didn't bump the voltage up.
No I didn't touch the voltage, and I'm not planning to ..
I see, so is that a bad thing for (meaning for choosing this card) any thoughts on that card in general. I'll leave it at +140MHz.
Assuming the card can boost up to 1.9GHz, maybe 2.0GHz (I don't believe it stops at 1.755), then 0.14GHz is barely even 5% better performance and that's assuming clock speeds and performance scale linearly (which they likely don't)
You're not losing much here.
Yes, it does go over 2.0 GHz in gaming .. thanx for the response.
It's not bad at all, though it doesn't amount to much, since the Gpu Boost algorithm draws out the vast majority of performance out of the cards anyway.
If that card had higher power limits than it already does, it would run warmer. Higher thermals leads to lower sustained boost frequencies if that extra heat isn't accounted for.
Reactions: MoeNAGY
Thanx
