GPU upgrade help
ArcticJ
5
Looking to upgrade my GPU but not sure where to start.
I have a core i7 920 @2.67GHz
GTX 260
12GB Ram
750Watt PS
I was looking @ getting a gtx960 but I dont think my current specs could handle it.
Would it be worth upgrading my GPU or should I start with my CPU ?
thanks for the reply ! okay so you think my current computer could handle a gtx960 though ?
haha was worried about processor since I currently only have a 260 - thanks for the reply <3
The gpu will definitely be a better upgrade than the cpu, and to see if your cpu is really bottlenecking the gpu, just check the cpu usage while gaming. The truth is the i7 is probably a lot closer to 2GHz on a newer i7 which is pretty low but should still be fine.
Your i7 can handle any single card on the market
Overclock your i7 and it wouldn't bottleneck almost any SLI configuration either
Thanks Luco - thanks 2 all the replies problem solved 😀 wish I could pick as best answer but didn't "Ask The Community" like I should have when posting new thread. Cheers
