GPU upgrade will it work with my build?
iiiraz3riii
hello im wondering if i can run a gtx 1080ti strix with my set up my specs are...
(Currently gtx 1070 strix)
I7 6700k
16GB RAM 3000mhz
Z170 pro gaming motherboard
850W evga platinum PSU
i was just wondering firstly if my psu can handle all of that without it being to much.
secondly i was wondering if that GPU will connect to my power supply? I am new to the pc world so any help will be appreciated.
Thank you for your time.
thank you for the fast response :) yes i have just found out that it has those pin slots. Thanks again!
Thank you for the fast response. brilliant news :) i think i may have to upgrade soon then 😀
