GPU using too much power
Dandog117
16
Hi,
I recently bought an Asus 970 4GB graphics card. It has been running fine for the past three weeks. Today, the computer turns on for a split second then turns back off. I did some troubleshooting and I believe the GPU is using too much power. When I unplugged it it worked fine but when i plugged it in again, the on/off thing happens. Is there any way I can use less power? I have an EVGA Supernova NEX650G.
Thanks!
A GPU doesn't use much power at POST. You should test the GPU in another system to make sure it isn't defective.
My previous card was an EVGA 750ti
Sadly, I don't have another system to test in.
