[SOLVED] Graphic card issue gtx 1050ti
Jan 29, 2019
Looking for some advice gpu was running fine not problem for over a year now all of a sudden it’s acting up a bit when looking at screen it’s like really bad graphics kinda blurry looking only way to describe it really
I’m running an i5 7400k
GTX 1050ti
16g ram
1tb hard drive
If it looks the same with the card in the slot and the card out of the slot, I would be inclined to look at a software issue next. Leave the card out for now and run off the integrated graphics.
Run CCleaner and do the Clean and Registry portions both using the default settings. Run it a 2nd time.
If still no joy, is it possible that it is the monitor that is failing? Do you have access to another PC or laptop to plug into that monitor?
