Graphic Designer Build help
Jojonephew
23
Hello people, I am troubled to pick a pc build for graphic designer ny budget is around 2.5k euro 4k monitor included thanks.
What programs do you use are there any secondary purposes? Do you need a secondary monitor (a must have)?
I did 2 years of graphics design on a cheap i5 3350m machine with 8gb of ram and was fine so I need some more info since you can do with very little and get a lot done unless you need a specific usecase that needs more power.
Thanks for answering jaslion, it will mostly be used for photoshop, sketchup the computer is build for my sister as she is starting her business into an interior designer so I need something that will make her work done flawless.
