H HokageMTN Reputable Nov 25, 2014 16 0 4,510 Jun 26, 2015 #1 Can i use any GDDR5 graphics card with Asus P7H55-V motherboard?
Solution S S Sahaj Pal Jun 26, 2015 Yes. DDR restrictions apply only for RAMs A GPU can be either a DDR3 or DDR5, your choice irrespective of the type of motherboard you have.
S Sahaj Pal Honorable May 15, 2013 286 0 10,860 Jun 26, 2015 Solution #2 Yes. DDR restrictions apply only for RAMs A GPU can be either a DDR3 or DDR5, your choice irrespective of the type of motherboard you have. Upvote 0 Downvote Solution
H HokageMTN Reputable Nov 25, 2014 16 0 4,510 Jun 26, 2015 #3 Does the memory of Graphics have any restriction? I want to use SAPPHIRE DUAL-X 100373L Radeon R9 280 3GB 384-Bit GDDR5 PCI Express 3.0? will it work? any compatability issue? Upvote 0 Downvote
H HokageMTN Reputable Nov 25, 2014 16 0 4,510 Jun 26, 2015 #4 or plz tell me a better 3GB GDDR5 card ....🙁 Upvote 0 Downvote
S Sahaj Pal Honorable May 15, 2013 286 0 10,860 Jun 26, 2015 #5 Yes it will work. I see no compatibility issues Upvote 0 Downvote
H HokageMTN Reputable Nov 25, 2014 16 0 4,510 Jun 26, 2015 #6 ok ... Jazak Allah and Thanx Upvote 0 Downvote
