Hi guys, how are you all doing
Recently I bought graphics card to replace my old one. But I found that the bracket for my new card was a bit short to fit in my case. The bracket holder? on the case stops the card from being installed completely into the pci-e slot; it stops when it's half way through.
Help me out guys what should I do 🙁
Just in case, the case I have is the Corsair Carbide SPEC-02
and I'm trying to fit a Sapphire R9 380X in the case.
