Monitor - Asus vg248qe
PSU: rm 650x Gold Corsair fully modular
CPU: i7 9700k
GPU: Gtx 970 (trying to upgrade to a 2080 ti)
Motherboard: Gigabyte B360M DS3H
2X Vengeance LPX 8GB ram sticks
Both the rtx 2080 ti and my old gtx 970 are displaying these issues.
The gtx 970 allows me to use a DVI cable to connect to my monitor, which in this case the display works perfectly.
However, recently I just purchased the 2080 ti which made me purchase a display port cable. I've tested this cable on both graphics cards and no display turns up. I also tried an HDMI cable which also gives me no display and the cables do work because I've tested them on the motherboard itself and it has given me display.
I'm looking to purchase a DVI to display port cable next, will that work? And even better yet, can someone tell me why these cables won't work for my GPUs because I'm probably doing something wrong.
*I want to note that I've done all the troubleshooting for the google search "No display monitor GPU" and other searches similar to that. I'm pretty sure my rtx 2080ti isn't "broken"
Heres a link to the display port cable I bought: https://www.amazon.com/gp/product/B078HVDMW2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
CPU: i7 9700k
