A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #1 I put in my bros GPU (GTX 770) and my keyboard and mouse will not turn on and my monitor will not post anything but when i look in my pc the gpu fans are running but when i put my gpu back in my pc GTX 1050 ti everything works fine
Solution COLGeek Aug 16, 2018 amingherib : COLGeek : It is likely defective (dead) based on these results. You did hook up the required PCIe power connectors from the PSU to the GPU, right? Yeh Then the GPU is likely DOA.
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #2 but when i put my gpu back in i get a warning saying previous overclocking failed Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,235 3,431 179,340 Aug 16, 2018 #3 What is the make/model of your power supply? The GTX 770 uses more power than the GTX 1050 ti. https://www.geforce.com/hardware/desktop-gpus/geforce-gtx-770/specifications https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1050/ Upvote 0 Downvote
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #4 COLGeek : What is the make/model of your power supply? The GTX 770 uses more power than the GTX 1050 ti. https://www.geforce.com/hardware/desktop-gpus/geforce-gtx-770/specifications https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1050/ My psu is corsair cx750m Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,235 3,431 179,340 Aug 16, 2018 #5 What is the make/model of your motherboard? Upvote 0 Downvote
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #6 COLGeek : What is the make/model of your motherboard? msi 970 gaming Upvote 0 Downvote
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #7 COLGeek : What is the make/model of your motherboard? Any ideas on what the cause is? Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,235 3,431 179,340 Aug 16, 2018 #8 Nothing comes to mind. I assume the GTX 770 works properly in your brother's system. Upvote 0 Downvote
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #9 COLGeek : Nothing comes to mind. I assume the GTX 770 works properly in your brother's system. we dont know atm as he doesnt have a good psu to run it Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,235 3,431 179,340 Aug 16, 2018 #10 I suspect the issue is the GTX 770 then, not your rig. Upvote 0 Downvote
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #11 COLGeek : I suspect the issue is the GTX 770 then, not your rig. Ok what do you think the problem may be? Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,235 3,431 179,340 Aug 16, 2018 #12 It is likely defective (dead) based on these results. You did hook up the required PCIe power connectors from the PSU to the GPU, right? Upvote 0 Downvote
A amingherib Prominent Nov 23, 2017 35 0 530 Aug 16, 2018 #13 COLGeek : It is likely defective (dead) based on these results. You did hook up the required PCIe power connectors from the PSU to the GPU, right? Yeh Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,235 3,431 179,340 Aug 16, 2018 Solution #14 amingherib : COLGeek : It is likely defective (dead) based on these results. You did hook up the required PCIe power connectors from the PSU to the GPU, right? Yeh Then the GPU is likely DOA. Upvote 0 Downvote Solution
