There aren't even 4-pin PCIE cables. You'd be looking at 6 pins or 8 pins (typically the latter in 6+2).
The power supply is a EVGA 600GD.There aren't even 4-pin PCIE cables. You'd be looking at 6 pins or 8 pins (typically the latter in 6+2).
If you don't have the proper cables, you need a new PSU. Adapters are a common source of fires and if your PSU is so low-quality that it doesn't have the proper port, you don't want to be using it in any case.
What is the exact power supply? Can give you a more specific answer; this is crucial information that's missing.
So it does have the correct cables and stuff to connect to a gtx 1660? I'm kinda new at this stuff and haven't installed a new gpu ever. It looked pretty easy, but i couldn't find any ones that would fit in the gpu.An EVGA 600 GD has two 6+2 pin PCIE cables. Since this is a non-modular power supply, you can't have misplaced them either!
