Graphics card not detected
phlo
7
My CPU (i-5) fried while under waranty. I installed the replacement CPU and there was no output from the graphics card. I plugged it into the integrated graphics and that works, but the GTX 960 is not detected. I've tried updating drivers, updating the BIOS, reseating everything. The card was tested in another computer and works fine. The NVIDIA utility won't detect it either. The BIOS is set to PCI-e. This is the same set-up that worked for 2 years, so all the hardware is compatable. I'm running Windows 10. Can anyone help me out?
1| When posting a thread of troubleshooting nature, it's customary to include your full system's specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
2| How old is your PSU?
3| Can you define how the system fried? Was it due to a lightning strike or a power outage?
It seems like your motherboard or your GPU might be fried but then again it could even be that your PSU can't deliver the necessary power to your system with a discrete GPU populated.
My bad, I've included the hardware below. I'm running the latest version of Windows 10. The PSU is 2 years old and has run all of the hardware in the past. I replaced the CPU with the same model. The CPU spontaneously crashed, no lightning or power surge that I am aware of. I was playing Half Life 2, so not particularly taxing for my rig. The GPU has been tested and is not fried. The motherboard seems fine, and all of the other features work normally.
GIGABYTE GeForce GTX 960 DirectX 12 GV-N960WF2OC-4GD 4GB 128-Bit GDDR5 HDCP Ready SLI Support Video Card
Intel Core i5-6500 6M Skylake Quad-Core 3.2 GHz LGA 1151 65W BX80662I56500 Desktop Processor Intel HD Graphics 530
Rosewill Quark-550, Quark Series 550W Full Modular Power Supply with LED Indicator, 80Plus Platinum Certified, Single +12V Rail, Intel 4th Gen CPU Ready, SLI & Crossfire Ready
GIGABYTE GA-B150M-D3H (rev. 1.0) LGA 1151 Intel B150 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
CORSAIR Hydro Series H50 120mm Quiet Edition Liquid CPU Cooler – Intel Only
Cooler Master Silencio 352 - Silent Micro ATX Computer Case with two fans, Sound Dampening Panels and Multiple Removable Air Filters
HyperX FURY 8GB 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Desktop Memory Model HX421C14FB/8
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
Rosewill RNX-N150PCe - Wireless N150 Wi-Fi Adapter - IEEE 802.11b/11g/11n, (1T1R), Up to 150 Mbps Data Rates, PCIe 2.0 Interface, WPS Supported
The card worked for 2 years. I thought it must be the card so I sent it to Gigabyte. They tested it and said everythig checked out after multiple tests. I put it back in my computer and still nothing.
Any ideas? I think you might be on to something, Lutfij. What would a motherboard failure look like? The PCIe slot is the only piece of hardware I haven't been able to test, but as far as I can tell everything else on the motherboard is functioning. The set up worked before, but I was running all of my graphics outputs off the card only. I thought I was way under budget on power usage, but I don't know what the integrated graphics would draw. Not that it helped, but I also did a reinstall of Windows last night, so there's one more solution to rule out.
I have also faced this when I bought my new phone. the graphics card didn't detect after trying again and again. I use it in another device then it detected and worked properly. there was a settings problem which was solved with the help of Mobile Repair Dubai. if you can't solve this yet you may visit once. I assure you that you will definitely get proper solution.
