It's going to be a long night... I'm stuck. Here's what I bought and plugged in today. The MicroCenter salesman said I could easily assemble it myself and don't need the $80 installation. Yeah right!
i5 3570K
Asrock Z77 Pro4
Gigabyte GTX650
8gb (4x2) Crucial RAM D3 1600
Thermaltake TR600 600W ATX
I was getting 3 long post beeps but reseated the RAM and now no beeps but the monitor goes right into sleep mode. I can't see a BIOS screen or anything. Here's what I've done so far:
Insert CPU into mobo
Place heatsink onto CPU
Plug 4pin cable into mobo
Insert 2 RAM (tried A1 and B1 slots first, then A2 & B2)
Insert GPU into the PCI-E 3.0 x 16 slot
Plug power supply 24pin cable into mobo
Plug 8pin cable from power supply to mobo (ATX 12v1 slot)
Plug 6pin PCI-E cable from power supply to GPU (the same cable also has a 6 plus 2 coming out of it; tried that as well but didn't know where to plug the 2 part)
Plug speaker from case into (4pin) speaker slot on mobo
Plug VGA cable from monitor to GPU
Plug in monitor, turn on
Set PS jumper to 115
Attach power cord to PS and plug in to wall outlet
Turn PS on
Jump the mobo on by touching the power prong thing on mobo with a screwdriver
Unit powers on, GPU fan spins, CPU fan spins, Monitor goes into sleep mode. I've tried switching a couple of cables where I could, changed the RAM slots, etc. Not sure what else to do since I can't even see the BIOS or anything on monitor. I have other parts such as HDD, SSD, case, etc. But I haven't even installed those or the mobo or anything into the case yet. There are a bunch of other cables coming out of the PS. Do I need to plug those in somewhere? Is the monitor shot? It's an older Dell 21" LCD. At least 5-7 years old I guess. The display isn't entirely dead because it does say it's testing and then going into sleep mode.
Thanks for your help!
i5 3570K
Asrock Z77 Pro4
Gigabyte GTX650
Turn PS on
