Graphics card overheats too easily and grey lines come up
jayrobert
14
I have an xfx 7950 and it overheats really easily while playing games but idle temps remain normal which is around 30 degrees. I've applied new thermal paste many times and i get the same result.
Forum guidelines - post your build. It might be lack of case fans, crappy power supply etc.
Also - download and install HWInfo. Post psu voltages - 12v, 5v, 3.3v - min and max plus gpu voltage and fan rpms
Also - post your graphics card settings - Afterburner or whatever you're using.
most common signs are crashing, system shutdowns, poor performance
always best to monitor temps with something like gpuz or hwinfo now and then, just to see how things are running
