Solution maxalge Jul 23, 2017 Nathan_161 : What is a 2x 4+4 PIN? that is for the motherboard cpu power graphics cards require 8-pin, or 6-pin if your power supply does not have the pcie cables the video card needs, then you need to buy a new power supply that does have them
maxalge Champion Ambassador May 31, 2012 13,372 4 56,960 Jul 23, 2017 Solution #2 Nathan_161 : What is a 2x 4+4 PIN? that is for the motherboard cpu power graphics cards require 8-pin, or 6-pin if your power supply does not have the pcie cables the video card needs, then you need to buy a new power supply that does have them Upvote 0 Downvote Solution
