Hello! I am having a problem that I can't seem to figure out.
So I got a graphics card 3 months ago gtx 1060 6gb, it worked fine for the 3 months I had it, suddenly when I turn my computer on the fans turn on the lights in the pc turn on, but the nothing else happens, there is no display on the screen of my monitor? Also I would like to add that the mouse likes don't light up either incase that helps, I thought it shows that no power is getting through.
So I swapped the card out to my old one, gtx 550 ti and it works fine! So I thought the card is dead... sent the 1060 back got a refund got a new card plugged it in... Nothing.... It does that same thing! So I put the card in my brothers computer and his computer turned on fine, so its not the card I tried swapping the power supply (more info on the hardware at the end) still the same problem. We have tried uninstalling drivers turning off intergrated graphics, etc the thing is when the card is in the pc I can't even use the intergrated graphics or nothing I have to remove the card completely then turn it on for anything to show up? I also tried removing the hardrive and turning it on incase its a problem with windows, nothing. I took out the battery on the motherboard and put it back in after 10 minutes, and you guessed it... nothing.
I don't know what to do I have been debating getting a new motherboard? The thing is the computer works with my old card just not the new ones all of a sudden.
SPECS:
Gtx 1060 6gb
amd fx 8350 (none overclock)
1tb hardrive
Corsair GS600w Other one I tried was the same, 600w not sure the brand sorry.
GA-78LMT-USB3
SPECS:
Gtx 1060 6gb
1tb hardrive
GA-78LMT-USB3
I think I will order it then! If it still does not work I really don't know
