[SOLVED] graphics card problems
gazza26
28
My text on my pc has gone a bit blurry and grainy. i have looked at the graphics card and it says this. im guessing theres a problem with it any one know how to fix it or what it means? als ohow i can get my text to be normal again,, thank you
Driver Management concluded the process to install driver nv_dispi.inf_amd64_8e1b465b962975a0 for Device Instance ID PCI\VEN_10DE&DEV_1401&SUBSYS_32011462&REV_A1\4&1286464&0&0008 with the following status: 0x0.
Use DDU to remove the old GPU drivers, and reinstall the new ones from the website for that GPU manufacture. Also make sure your resolution is set correctly in settings.
