D
Deleted member 2757806
Guest
7 months ago I bought my new computer, and ever since the first couple of days it has been randomly freezing and stuttering to the point that I have to completely restart it and unplug it from the power source for a couple of minutes, just so I can turn it back on (otherwise the monitor stays black).
I sent my PC to the technicians twice, and both times they were unable to find any issues, followed by them also changing my graphics card the second time, in the hopes that it will fix it - however this has not worked. I re-installed my nvidia drivers with DDU as well and this did not help either.
the issue does NOT come up when I use my old 60hz monitor connected with hdmi. The only way I have experienced this happening is using my new monitor (144hz) connected with displayport so it can actually show 144hz. I did not test for 2~ weeks with my new 144hz monitor connected with hdmi so it shows 60hz, but in the time that i did test... the crash did not happen and it seems to work fine like that as well.
so now combining everything above, this makes me believe that somehow the issue is with the monitor itself when its connected using a displayport cable? (i tried a different DP cable but it did not help)
so all that being said, what should I do? what can I do? why would this issue be happening when the monitor is connected using displayport? is there an explanation for this? every other combination seems to work, and of course I refuse to use a 144hz monitor at 60hz just because of this crash. I'm really frustrated after dealing with this issue for 7 months I tried so many things but nothing has helped... I really need help and guidance, I'm lost at this point and I don't even understand why this is a thing. please help
also the only thing on event viewer when the freeze/stutter/crash happens is a nvlddmkm (event id 14) error that has a /device/video3 0cec(3098) information
GTX 1660 Ti (6gb)
Ryzen 5 3600 (6 cores)
16gb Ram
1920x1080 144hz
it doesnt matter whats happening on the PC at the time. it crashed while I'm playing a video game, watching youtube, browsing the internet, while everything is idle... IT EVEN HAPPENED literally like a few seconds after turning the PC on after its been turned off for 9 or so hours
GTX 1660 Ti (6gb)
16gb Ram
1920x1080 144hz
