Graphics card showing 0Mhz in clock speed!!
If you really don't know what that is, or why it was there, you should really run a good virus scan:
https://www.malwarebytes.com/
HOonix
85
Thanks, but I resolved the problem by myself.
What I did was I went to the Device Manager , clicked on the Display Driver and disabled something called 'my hook display driver 2' and I restarted my PC.
And then I saw that GPU-Z detected my GPU!
"How do I disable the integrated graphics?"
If necessary, in the BIOS settings. I say "if necessary" because on many boards it's disabled automatically when an add-on GPU is detected.
On my ASRock board I had to change BIOS setting from "integrated" to "PCI Express", then save & exit the BIOS.
HOonix
85
it_hurts_90
Same problem in my rx 470. Gpu z doesnt show gpu core-0 mhz, memory-0 mhz,
pixel - unknown
texel- unknown.
And even in msi afterburner core 0 memory 0
Plz help
