So my PC wasn’t booting up and I thought I plugged in some things wrong that were under the graphics card. I decided to try to pull my graphics card out and forgot to hold down the clip. I pulled forcefully (smh I’m an idiot) and now some of the pins are out and a few are still in and the graphics card is still clipped in. I tried getting it back to fully in but that wouldn’t work. I tried to pull it out and it was still stuck. The clip also won’t budge. Any and all help is greatly appreciated. Thank you.
SOLVED: I ended up applying pressure on the clip and broke it off, and I successfully removed the graphics card. The clip is only to hold the graphics card in, correct?If I screw the graphics card into the case then will the clip not be necessary?
