Hello Tom's Hardware Community
My graphics card (Gigabyte Windforce 3X GTX 670) is stuck with my power cables ( I have an HX750 from Corsair which is modular ); I would like to remove it and replace it with a GTX 770/780 when it comes out and I wouldn't be playing any games until then (too busy). I wouldn't be able to do that because the power cables don't match up with each other unless I buy another HX/TX series psu! What do I do? How can I remove the power cables to the card? It's been taking me alot of strength in attempting to remove the power cable from the card. I also used the prong thingy to "unlatch" the connector(s) but it isn't making it much easier. Are 6pin/8pin power cables usually this hard to remove? Thank you.
