Graphics card too hot???
yannifb
1,106
My soon to be old computer (building a new gaming system) uses an Nvidia geforce 8800GTS. It's temp is around 60 idle, but goes up to around 87 when gaming!!! Is this normal for that card?
Also ive bought gtx 295's for the system im building and i'm wondering if you guys know what there average temps would be with good airflow.
87 isn't the max that the card can handle but it's on the high side. What is the GPU fan speed at that temp? Have you tried to manually set the GPU fan to 80 or 90 percent to try and keep it cooler? By doing so, it should not peak above 80.
