Hi
So I use my current work desktop for Civil 3D /Navisworks. I’m going to back to my office part time (post pandemic) so need to fire my old desktop back up. It is struggling a bit with the bigger models I am thinking to upgrade the graphics card to try and bring it up to speed with my work desktop.
I don’t really have much experience but I just had a go at taking the current graphics card in and out and it wasn’t that hard. Also, I don’t really mind if a break it, this upgrade is the last chance band aid before I have to buy a new one. Current specs are:
• HP Z400 Workstation
• X64 – based PC
• Intel Xeon W3520 @2.67 GHZ, 2661Mhz, 4 Cores
• RAM 24GB
• Nvidia Quadro NVS 295
https://ibb.co/sHkHCPm
https://ibb.co/m0JJ40c
So I am asking (very nicely
) specifically:
• How likely is it a Quadro K2200 for £60 from ebay would work in this old machine.
• Would it speed up my work or would something else (CPU for example) just hold it back anyway.
• Will a run into any installation complications, like connecting a power cable or something, or is it just in and out.
• Any thoughts on a more appropriate upgrade.
Thanks in advance for any help you can give!
• X64 – based PC
• RAM 24GB
