Graphics card very hot with side panel on
grumpymonk123
37
My graphics card gets ~80 degrees C while gaming which I know isn't that high but if I take the side panel off, it goes down to ~70 degrees C. How can I fix this? Idles temps improved from ~50 C to about ~45 without the side panel as well.
80'c when gaming is totally fine on that GPU. The 290/390 are power heavy hot running gpus. Theres nothing to worry about at all.
The reference 290 would hit 95'c under load, which AMD said is normal.
What would be the best configuration for the corsair carbide 100r? I've tried rearranging the fans and it didn't change much.
I have 2 intakes in the front and 1 fan in the back and 1 fan with a radiator on top.
