Graphics card with passive cooling
xitaah
58
Hi
I'm looking for a graphics card with passive cooling, that can run Wolfenstein: The New Order. It doesn't have to be at maximum quality, but the higher the better.
Does such a card even exist? I've heard about GTX750TI with passive coolers, but would prefer a direct answer from you guys.
Thanks in advance.
I'll assume you're in the USA for now.
Newegg has no passive cooled GTX750Ti cards but they do show this GTX750 (not the Ti version) with a passive cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121911
Be aware that passive cooled cards still need some reasonable airflow through the case or they WILL overheat.
There is plenty of nearly silent cards out there, why go passive?
Wolfenstien TNO can be demanding at the higher settings, if you're having issues with your current setup try: Set shadows to a lower setting, enable VT compress and turn Screen Space Reflections off.
batman1130
8
batman1130
8
I have AMD Sapphire Ultimate R7 250 running on my Lenovo M83 (Intel i7 CPU - Windows 8.1) and I couldn't ask for a better passively cooled card. My only problem is that I don't seem to get it to work well connected via "Display-Port" - HDMI works perfectly.
