[SOLVED] Graphics Card wont work
Oct 13, 2021
Im using ryzen 3 3200g and the Vega 8 graphics it has, now that I tried adding my old gpu it wont work, do I need to download the drivers first?
To be honest, from what I can see, the vega 8 performs better than the GT 730 anyway, I would just keep using the 3200G if I was you.
Ryzen 3 3200g
16gb ram
Gigabyte GA-A320M-S2h V2
and I wanna add my old gt730 , I guess its a downgrade but its just lying around and would be a waste if it doenst get used
yes I did plug the monitor cable to the gpu
Ok thanks, Ill just wait till I can buy a suitable graphics card and see if it works, if it doesnt Ill be back asking the same question. For now Ill continue using the vega 8
Reactions: kurdtnz
