Graphics Upgrade help
Cool, thanks. The Hd7790 is 10% Cheaper as well over here.
Both HardOCP and Guru3D still got a 20% core overclock out of it, which is similar to what you can expect to get with a voltage bump on the GTX 650 Ti.
Yes reason I want Radeon is because of the "Possible" advantage with next gen consoles also using similar hardware and well it is faster than the Gtx650Ti and cheaper. So what's not to like?
It was just an example to show that they cost about the same in the US (so they should cost about the same in other countries too).
The higher prices you see are probably partially caused by VAT. Here in Denmark for example, the cheapest GTX 650 Ti is $157 and the cheapest 7790 is $165. That's approximately the US pricing plus our VAT rate (25%).
Wow things seem pricey there. Better get the 7790 instead unless you want to do some mid range OC.
Ok so now I came across another card at the same price. A Powercolor 2gb hd6950 stock. How will that be? In crysis3 I see it just above a Gtx650Ti or has performance increased with driver updates? Does this Card support DX11.1?
I have a Corsair Cx 500w v2 80+ Bronze. So which one would be better?? Or which one would you pick in this situation? I know powercolor isn't most reliable?
You sure? The Hd6950 draws 16.5Amps and my cpu Fx6300 8Amps. My Psu has 38Ams Continuous Power available
Well lets say I did upgarde my psu? Which one would be better? I see the Hd6950 also only has dx11.0
They are $100 more expensive here in SA, that's insane and way out of my budget. I'll just stick with the Hd7790 then. Unless you know of a trusted US based online shop that ships to SA??
