[SOLVED] - Loud fan noise that goes away after restart / putting the PC to sleep?
Hello all! For a little while now I've encountered this strange problem with my PC. Sometimes ( not all the time ) the fans will be noticeably loud and make a kind of " whooshing " sound after start-up or after starting to run a game. The sound does not go away on its own and has persisted...
^^^ This is the most similar thread I have found regarding my problem but I struggle to understand the Best Solution as I'm not that proficient regarding PC Specs and tech talk.
Whenever I boot up my PC after some time off it does this grinding sound coming from the CPU dissipator's fan. I opened it up and cleaned it and even moved the fan a little to make sure it wasn't some physical problem and something was actually grinding on the fan, but the problem persists.
I don't understand the previous post's solution, seems like it's not a big deal but if there's an easy way of fixing this, I'd like to know.
EDIT 1:
Tried again after leaving the PC shut for a few hours, the noise began again but I let it run and after 5 minutes or so it was back to normal.
EDIT 2:
Specs
Processor | Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz |
Number of Cores | 4 |
Speed | 3.9 GHz |
Stepping | 3 |
Family | 06 |
Model | 5E |
CPU ID | BFEBFBFF000506E3 |
Memory | |
RAM | 16 GB |
Video Card | |
Video Card | NVIDIA GeForce GTX 1070 |
Chipset | NVIDIA GeForce GTX 1070 |
Manufacturer | Nvidia |
Hardware T&L | Yes |
Total Menmory | 16 GB |
Dedicated Memory | 8.0 GB |
Driver Version | 31.0.15.1694 |
Vertex Shader Version | 5.1 |
Pixel Shader Version | 5.1 |
Plug and Play ID | VEN_10DE&DEV_1B81&SUBSYS_85A01043&REV_A1 |
Device | 1B81 |
Vendor ID | 10DE |
Operating System | |
Size | 64-bit |
Operating System | Windows 10 |
Version | 10.0.19041 |
Service Pack | 0 |
Locale | 0409 |
BIOS | |
BIOS | BIOS Date: 02/23/16 22:28:46 Ver: 05.0000B |
Manufacturer | American Megatrends Inc. |
