For those of You that still don't believe in ESD: there are an EOS/ESD Association and standards:
https://www.esda.org/
Then it is more to this:
Two materials of two different kinds are an object to ESD.
Controlling electrostatic discharge begins with understanding how electrostatic charge occurs in the first place. Electrostatic charge is most commonly created by the contact and separation of two materials. The materials may be similar or dissimilar although dissimilar materials tend to liberate higher levels of static charge. For example, a person walking across the floor generates static electricity as shoe soles contact and then separate from the floor surface. An electronic device sliding into or out of a bag, magazine or tube generates an electrostatic charge as the device's housing and metal leads make multiple contacts and separations with the surface of the container. While the magnitude of electrostatic charge may be different in these examples, static electricity is indeed formed in each case.
Creating electrostatic charge by contact and separation of materials is known as "triboelectric charging."
When the two materials are placed in contact and then separated, negatively charged electrons are transferred from the surface of one material to the surface of the other material. Which material loses electrons and which gains electrons will depend on the nature of the two materials. The material that loses electrons becomes positively charged, while the material that gains electrons is negatively charged.
Static electricity is measured in coulombs. The charge “q” on an object is determined by the product of the capacitance of the object “C” and the voltage potential on the object (V):
q = CV
Commonly, however, we speak of the electrostatic potential on an object, which is expressed as voltage.
Virtually all materials, even conductors, can be triboelectrically charged.
The amount of charge is affected by material type, speed of contact and separation, humidity, and several other factors.
* Charged objects have electrostatic fields.
* Electrostatic discharge can damage devices so a parameter fails immediately, or ESD damage may be a latent defect that may escape immediate detection, but may cause the device to fail prematurely.
* Electrostatic discharge can occur throughout the manufacturing, test, shipping, handling, or operational processes, and during field service operations.
* ESD damage can occur as the result of a discharge to the device, from the device, or from charge transfers resulting from electrostatic fields. Devices vary significantly in their sensitivity or susceptibility to ESD.
Best regards from Sweden
Ps.
How to Power a Light With Static Electricity
And
Fluorescent Lights under High Voltage Power Lines!
