[SOLVED] Gskill aegis ddr4 8gb x 2 3200mhz not stable at 3200mhz?
poorbugger
Here's my specs.
Gtx 980 ti
Asrock b450m pro4
Ryzen 5 2600
Corsair CX550M
After figuring out why im getting errors of games crashing to desktop randomly with exception code 0xc0000005, i manage to narrow it down to maybe it's the ram. This problem only occurred about a week ago but i built this pc a few months ago. Previously my ram was on xmp profile 3200mhz but since last week, games have been crashing due to that error in the event viewer. So now, i set it on 3000mhz and so far it's stable. But i paid for 3200mhz ram not 3000mhz. Any ideas why it just started happening last week? Games that have been crashing on me are rdr2 and smite.
Apparently upping the voltage to 1.4v seems to be stable for now. I played rdr2 for 2 hours with no crashes whereas i crashed in the first 30 minutes before
That is freakin great news my friend. Ya when you up the voltage it can handle tighter timings and a higher Mhz. It is a same soo many people have this same problem as you, you would think we have advanced from DDR3.. sighs 😏
Here's my specs.
Gtx 980 ti
Asrock b450m pro4
Ryzen 5 2600
Corsair CX550M
This error can really come from anything, software or hardware.
See https://www.stellarinfo.com/blog/how-to-fix-error-code-0xc0000005-in-windows/
Did you change anything on your computer just before this started: new software, changes in WIN10 ?
Here's my specs.
Gtx 980 ti
Asrock b450m pro4
Ryzen 5 2600
Corsair CX550M
3200 is a overclock setting and not guaranteed to run without adjustments just leave it at 3000.
Anything over 2667 is a overclock on the motherboard and the CPU is 2933.
Well, could be a hardware problem with the gtx 980 ti. If you still have the rx 580 maybe put it back, and see what happens
Zen+ CPUs won't go above 2933 (or 3000) reliably, at all. The 3000 series can be stable, but not the 2000 series. You're capped at 3000mhz.
Thanks for the replies. I upped the voltage to 1.4v instead of 1.35v. im running memtest86 now as we speak. Previously i only used windows memory test that took only a few minutes. Im hoping memtest86 would yield better results.
Forget X.M.P you must manually enter in the RAM timings for each channel, so get the specs of your RAM and put in those latency numbers then set to 3200Mhz and you should be fine. Good Luck 😏
