| Corsair CXM (2015) 450 W 80+ Bronze Certified Semi-modular ATX Power Supply |
Cooler Master MasterBox Q300L MicroATX Mini Tower Case |
MSI GeForce GT 1030 2 GB Video Card |
Team GX2 512 GB 2.5" Solid State Drive |
ADATA XPG Z1 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory |
MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard |
Thermaltake UX100 38.82 CFM CPU Cooler |
AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor |
get a cpu that works in the mobos chipset stock to see what that cpu may be conact msiHow would I update the bios?
How would I enable the integrated graphics of the computer?Where are you plugging in the monitor?
You have the 3200G which is basically as good as the 1030. Just try using that right now.
I took out the graphics card and plugged the HDMI cable into the motherboard's HDMI slot. the VGA on the EZ debug light was yellow again, meaning I think it isn't even detecting the integrated graphics.How would I enable the integrated graphics of the computer?
How do I update the bios?If it doesn't boot with that cpu installed and you are sure everything is plugged in correctly, then it does appear it needs a bios update. The 4xx chipset works with the ryzen 2xxx cpus "out of the box." It will work with the ryzen 3xxx, but only with the newest bios. Updating to that level will remove support for the ryzen 2xxx and below. It will never work with those cpus again.
