Question Gt 1030 problem ( weird)
Apr 21, 2020
11
Hi everyone,
here again, i don't really know if you could help me with this issue, i've been searching info about this bug for 2 weeks i guess, and i don't know what to do,
first at all, let me explain the situation,
i have an old pc, is a optiplex 745 Desktop, with a Intel Core 2 Quad Q6700 (socket 775 LGA), 8 gb of ram and GT 1030 GDDR5 2gb
when i bought the video card (october 2020) i didn't have any problem with it, i just installed drivers with Driver booster and started play some games (fortnite, GTA V, CSGO) even old games like Age of Empires, Strongold Crusader, Zeus Master of Olympus, etc.
3 weeks ago, i've change my hard disk for another one, installed windows 10 normally, not any issue with it, everything was fine, i started to play fortnite normally but i was hearing something when started to play, everytime that I was dying or starting a match, i was hearing a buzz, lagging the music, the voices, everything for a while, some seconds 4 or 6 i guess, then everything just came back to normally but i knew that there was something wrong with it.
then i installed spotify and i was listening music, I start the game (fortnite) then the music was deformed, was slow, like if the speakers were damaged, closed the game then the music was fixed, launched the game again and speakers were doing the same "·!"· again.
I downloaded Age of Empires, Strongold Crusader, Zeus Master of Olympus and i can't play them.
when i try to play, is everything laggy, is nor playable, the music is damaged or broken, i don't know.
i've searching all the cases about this problems but i didn't find anything like that, i've heard about STUTTERING but everything realted with that, didn't work for me.
i've tried,
  1. re-install drivers /
  2. changed audio speakers frequency /
  3. installed olders and newers drivers,
  4. deleting drivers with DDU,
  5. using cmds like /sfcannow,
  6. / tested video card in other mainboard (worked fine) /
  7. desactivated telemetry /
  8. used LatencyMonitor to check what's going on with that but that show me this results:
more details here, pastebin : https://pastebin.com/UfYdj9Zc
BUT something weird happened, when i deleted video drivers (nvidia drivers) and installed Intel Q965 Chip set (video) drivers from default, everything was fine, i played stronghold crusdaer and age of empires, zeus, and other older video games normally, without that audio and lag problem, didn't have any issue, was fine, and latency was fine, so i said, sh*t i fixed the problem, then reinstalled drivers NVIDIA and the games was laggy again, a buzz in the music, voices and music was choppy again.
saw this video
View: https://www.youtube.com/watch?v=KEgSmbVc1D8
and in conclusion i had to use a program called Custom Resolution Utility to delete an extension (HDMI) because i was getting some resolutions out of range of my monitor but i didn't worked too.
i dont know how more explain this situation
but there is my pc specs and a video showing how my pc sounds playing and listening music from youtube (in october i could play videos and play fortnite without any problem, or any choppy music/sounds, i don't know why those simple games (talking about recurses) is playing in that way,
AM I MISSING ANYTHING? i can't see the problem, please, help me :c
proofs:
buzzzzzz
comparation
specs
PS. sorry for bad English is not my native lang, have a nice day and thank you for reading this post
-cheers
-Rafael
Bob.B
697
79
490
Hi everyone,
i've tried,
saw this video
proofs:
buzzzzzz
comparation
specs
-cheers
-Rafael
Since dell does not support w10 on that machine your into R+D mode.
Get the latest bios and chipset driver and test.
Run this and post a link........... PC Benchmark
Reactions: RafaelZam
Apr 21, 2020
11
Hey ! thanks for you reply,
I don't know, i didn't have any problem with my OS, what is R+D mode? should i disable it?
i have already the latest bios and drivers :/
i have not problems playing fortnite, 30+ fps stable, but with those games and videos ... is still hearing a buzz when i launch olders games and videos.
https://www.userbenchmark.com/UserRun/40399607
Bob.B
697
79
490
R+D mode means your doing something that is not supported and your on your own.
Reboot the machine and let it sit for 5 mins.
Run the benchmark and post a link.
Apr 21, 2020
11
https://www.userbenchmark.com/UserRun/40422624
but i don't understand, before installing again win 10 everything was fine, i didn't have any problem before that
isn't this problem related with resolution of something like that?
because my monitor doesn't support 1920*1080
i reinstalled win 10 new version 2009 to see if anything is fixed with that, nothing changed, help please:/
Bob.B
697
79
490
That benchmark looks better.
Run this........Speccy - Free Download
Read this and post a link to the speccy run.................. Speccy...publish
Bob.B
697
79
490
11
The speccy is showing you have 4 different brands of ram sticks and 2 different speeds.
This may be why the benchmark is showing a ram problem.
No idea if it has anything to do with your problem just something to keep in mind.
well, i don't think so, cause as i said, i've uninstalled my graphic card and used integrated graphics and games were running fine, and everything was fine with it, also tested gt1030 in other computer and didn't have any issue with it.
when i update use/install drivers from nvidia i get this error/bug
:C thank you anyway
