Gtx 1050 ti power consumption
Tuong_1
Commendable
Jul 16, 2016
4
Hi guys! I just upgraded my pc with new gtx 1050 ti. However, when I run GPU-Z and look at the sensors tab right at the power consumption area, it says 49,6% TDP when the computer is idle, and I am not gaming. Is that ok for the gpu to consume power like that? Thank guys
My specs:
Cpu: Core i5 3570 @ 3.4 ghz 3.8GHZ at turbo mode
Ram: Gskill 8gb ddr3 1600
Gpu: Gigabyte GTX 1050Ti OC 4GB
Mainboard: Gigabyte socket 1155 - H77M - D3H
Psu: AcBel G500W PCB027 (80 plus certified)
Hope you've solved it the same way i did; I had the same problem, TDP 49,4% at all times.
I plugged in Watt Meter and it showed the correct consumptions in all situations (8-10W rise compared to integrated graphics with multimonitor, which is the right amount according to reviews (Gigabyte GTX 1050ti 4G OC))
So GPU-Z, HWINFO, etc. have bad readings in terms of TDP, temperatures and load are correct.
I5-6500T skylake, 16GB DDR4 (2133mhz), Gigabyte H170-D3HP, 2xSSD + 1x7200ot, 2x display, 520Wpsu (80+)
So it was never faulty to begin with? It was just that the readers were the one at fault? Thank you for clearing this up!
