Gtx 1050 Ti to VGA Monitor
ThunderRainbow
Commendable
May 18, 2017
18
Hello mates,
I want to use the Asus Geforce GTX 1050 Ti Strix in my first PC build in a couple of months and as I am on a low budget I can't really buy a new monitor, so I was thinking about ways to maybe use adapters or special cables to link them up. As you maybe know, the 1050 Ti that I want to buy has a DVI-I port, which to my knowledge is an analog port.
Does that mean, that if I get the right cable or adapter I can link that up to my monitor? Thanks for the help!
Thanks for the answer, but after looking at some more reviews I found out it just has 2 DVI-D ports, which aren't analog, so what am I going to do now? Maybe buy an adapter from HDMI to VGA? Will that even work?
