GTX 1050Ti CSGO FPS HELP
ItzN8
Commendable
Dec 7, 2016
I just recently bought a 1050ti and installed everything last night. I tested out a few games, Minecraft, Watch Dogs and CSGO. This table will help explain what I want to say...
Minecraft: Previous FPS (50-80), Improved FPS with 1050ti (120-150)
Watch Dogs: Previous FPS (20), Improved FPS with 1050ti (60-70)
CSGO: The fps for csgo has not changed since I got the graphics card.
I was playing via VGA before I got the graphics card, now when I play on HDMI and use the card I get the same FPS. I will include my settings below, thank you in advance for the help!
https://gyazo.com/2f073ef1a8355a94f8406a9ae8dd853e
https://gyazo.com/62e3ec1b7fbb4f5dce1b16e79333cf6b
https://gyazo.com/38f3db1fbc569b2cdbe59f1f10bbea65
https://gyazo.com/014e9e638d91f9368d1ab6fc1d67a104
Im using Windows 8.1
GTX 1050ti windforce oc
AMD A8-7600
This is up to you.
Having V sync enabled in CS GO will lock the frame rate output as said to 60Hz or 60 Fps.
Turning it off may give you more frame rate count.
Run CS GO
Enable the developer console in the advanced settings options check the tick box that is assigned to the tild key on your keyboard. Exit back to the main menu or start CS GO
Hit the Tild key to bring up the console.
And type the command.
Fps_Max 100.
Press return.
xStampede
818
You might have Vertical sync turned off which limits the framerate to what your monitor can output, if you have 60hz (60fps) monitor then it limits it to 60fps.
Chenge graphical settings ingame, not throu nvidia control panel.
This is up to you.
Run CS GO
Fps_Max 100.
Press return.
