GTX 1060 compatible with ASRock 970 PRO3 R2.0 Socket AM3+ motherboard ?
My older motherboard is an ASUS M5A78L-M/USB3 and in my opinion the motherboard's chipset is too old and the gtx 1060 is using at least 970, chipset isn't that true ?
What do you mean the older one or that which I'd like to buy ?
Just because I tryed with the older one and it does not works when, I put the card in the PCI slot and after that turn on the pc the VGA is not give image in addition the output devices either works too when I pull out the card this problem is sloved. But my power supply is good enough for this card this is a 500W power supply.
