GTX 1060 Monitor
Yukiteru
Commendable
Dec 11, 2016
Hi guys!, I have bougth recently a gtx 1060 6gb oc, the thing is that when I connect to the MOBO, the image which I recived from mi monitor just stop. So I take out the GPU and try downloading the drivers at first, but another problem, an error just pop out saying that mi system wasnt cappable. Now im installing windows 10 and hope it work, PLS I NEED HELP!!
PD: SORRY FOR MY ENGLISH
If you connect your HDMI/DisplayPort/VGA/DVI to your motherboard, it will use the integrated graphics instead of the 1060. You need to plug the cable directly into your graphics card to use the 1060.
