Gtx 1060 temp too low?
davidparker72.dp
8
I've had problems with my graphics card. It requires around 200w and my psu is 500w. The Gpu is a msi Gtx 1060. Brand new. I've had it for a week. My display is will shut off 15 seconds when I turn on Pubg or other big games. When I run furmark to test it. It does does the same when I test it. But if I test it on 720. Then 1080 FHD. Then stress test it it works. I run the game and it works after I've done the first two test. But when the temperature gets low (around 50°) from the fans cooling it. It then shuts down the display. Any help?
Try to reinstall windows and disable the onboard graphics and enable the dedicated graphics in BIOS.
After that install the latest driver for the GTX 1060.
Also download MSI afterburner and enable auto fan mode.
Leave everything at stock settings and if nothing works then the PSU is most likely not enough for all your components.
I will suggest you to look for a 650W PSU.
