GTX 1070, i5 7600k, 144hz monitor???
Yummiesttag
63
I was wondering if a i5 7600k at stock clock settings and a gtx 1070 could handle a 1080p 144hz monitor.
I know it won't get 200+ fps but even if it got like 120 that's a plus
I5 will probably be pinned at 100% causing stuttering and fps drops in cpu intensive games but it will mostly do fine. I had a 4670k oc'd to 4.6ghz and it choked occasionally with my 1070. I also game on a 1080p 144hz monitor.
Gotta say BF1 is maybe the only game that makes an i5 suffer.
Generally an i5 is completely sufficient, BF1 is the exception to the rule
You won't hit 120fps in crisis 3 as well with the 1070 although it's pretty easy in all other games.
There are a few exceptions.
