GTX 1080 - Blinking white light?
Thicoo
4
Hey all,
I was just normally using my PC when it shut down. As I was booting, I noticed that the GPU had a flashing white light above its power cable.
Had no luck searching the issue, and this never happened before.
Any leads on what this may be?
Thanks in advance.
Update: Just noticed that the fans aren't moving. Still have no clue on what's going on..
Link to the image: http://imgur.com/a/IWrlW
The above answer saying it's "just connected" is wrong. It blinks if it is getting abnormal power. Check to make sure it's fully seated, I had this problem on my gigabyte gtx 1080.
So how to make sure it get stable power i am having gtx 1080 ti and 750w psu (wire is properly installed) which is having the same issue.
Please help me
Thanks in advance:)
in my case the cable wasn't full connected, it was a bit loose, so make sure it's snapped in. Maybe check the connection from the gtx cord to the psu too, if you have a modular psu
