Hi
if so, a brief answer is appreciated, if not, what components need changing?
I want to upgrade my system for BF1 in September.
Thanks
CPU
Intel Core i7 860
RAM
Memory slots
Total memory slots 4
Memory
Type DDR3
Size 8192 MBytes
Channels # Dual
DRAM Frequency 659.7 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Command Rate (CR) 2T
Physical Memory
SPD
Number Of SPD Modules 4
Motherboard
Manufacturer ASUSTeK Computer INC.
Model P7H55D-M EVO (LGA1156)
Version Rev 1.xx
Chipset Vendor Intel
Chipset Model DMI Host Bridge
Chipset Revision 11
Southbridge Vendor Intel
Southbridge Model H55
Southbridge Revision 06
System Temperature
Voltage
CPU CORE 1.088 V
MEMORY CONTROLLER 1.736 V
+3.3V 3.344 V
+5V 5.016 V
+12V 11.765 V
VIN6 0.064 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Thanks
CPU
Intel Core i7 860
RAM
Memory slots
Memory
Type DDR3
Size 8192 MBytes
Channels # Dual
Physical Memory
SPD
Motherboard
Version Rev 1.xx
Chipset Revision 11
System Temperature
Voltage
CPU CORE 1.088 V
+3.3V 3.344 V
+5V 5.016 V
+12V 11.765 V
VIN6 0.064 V
PCI Data
Slot PCI-E
Slot Type PCI-E
