Gtx 1080 Running 2 1440p and 1 1080p Monitor (60hz)
NightHawkS1
42
I'm looking into replacing two of my 1080p monitors with 1440p monitors, and I was wondering what the performance hit would be like.
I am well aware the going from 1080p to 1440p will require some settings to be turned down, however I was wondering if a GTX 1080 can handle 2 1440p and 1 1080p monitors without much performance impact if only one 1440p monitor is used for gaming.
That should be fine. When not in gaming, the GPUs aren't using that much processing power. As long as you are gaming on only one, you should be fine. The GTX 1080 is perfect for 1440p, and no settings should not have to be turned down.
