M.AGamer Honorable Feb 19, 2019 387 33 10,740 Mar 14, 2019 #1 Hello,i have cooler master mwe 500w(http://www.coolermaster.com/powersupply/mwe-series/mwe-500/) got only PCI-e 6+2 Pin and gtx 1660 ti required 8x1 will it work?
Solution Dark Lord of Tech Mar 14, 2019 Yes it will work , a 6+2 pin PCIE is an 8 pin PCIE and you should have 2: MWE 500 | Cooler Master Cooler Master MWE 500 www.coolermaster.com PCI-e 6+2 Pin x22
E ebosss03 Reputable May 1, 2018 478 17 5,015 Mar 14, 2019 #2 Short term yes, Long term, its actually nicer to have a PCI-e 6+2 Pin so if you have a six pin GPU you can aslo power it. Reactions: M.AGamer Upvote 1 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Mar 14, 2019 Solution #3 Yes it will work , a 6+2 pin PCIE is an 8 pin PCIE and you should have 2: MWE 500 | Cooler Master Cooler Master MWE 500 www.coolermaster.com PCI-e 6+2 Pin x22 Reactions: M.AGamer Upvote 1 Downvote Solution
