I'm currently running an MSI N470GTX (not the twin frozr) on a 19' LG@ 1366x768 res. The rest of my specs:
intel i5 760i@2.8Ghz
MSI H55M-P33 Mobo
4gb DDR3 Kingston RAM
CoolerMaster 700W Real Power PSU
CoolerMaster Elite 335 (2x120mm fans)
CoolerMaster Sentinel Advanced Gaming Mouse
Razer Carcharias Headset
Windows 7 Ultimate
Let's get the obvious out of the way! I know that the 470 is wasted on the existing Monitor/ resolution. I have full plans of upgrading to a 1920 Res monitor soon. The idle temp's are anything between 44-50.
Now, my concern. While playing games like AvP, Mafia II, GTA 4, COD4MW2, BFBC2, L4D2, MOH, etc the heat shoots up to 92 and ultimately settles at 90. I am also aware that the threshold for the card is 105 and anything under 95 should be considered ok. Ambient temp's are around 18-22 Deg Celcius.
But this is happening at a low res monitor!
What happens once I upgrade to a higher res monitor? Are these temp's likely to shoot up further? Does the resolution have a direct impact on the amount of power sucked in by the GPU? And does the same effect the temp's of the card? Shouldn't a lower res monitor take less power/ lesser heat?
Wanted to clear these apprehensions. Since I've recently bought the 470, I wanna rule out any possibility of a faulty card.
As always, appreciate the response.
MSI H55M-P33 Mobo
Windows 7 Ultimate
