Hello I recently bought a system built by a person that I have been using to play FFXIV. The setup is:
ASUS P7P55D-E LGA
i5 750 2.66GHz
RAIDMAX SMILODON CASE
PNY GTX 470
G.SKILL Ripjaws Series 4GB
Antec EarthWatts EA650 650W
Western Digital Caviar Black 640GB
Linksys PCI Wireless Adapter with Dual-Band
Windows 7 Home Premium 64 bit
Nothing has been overclocked to my knowledge and I play on a 20" Dell s2009w monitor. I have been playing in windowed mode at 1600x900 res, 2x MSAA, Standard shadow detail and texture quality and high texture filtering. While playing my GPU core temp has been running between 82-95C via CPUID Hardware Monitor. I would like to keep the card running about 10 degrees cooler and not sure what my best options are. Have been debating purchasing a aftermarket cooler like the Gelid Icy Vision, Zalman VF3000F or the Artic Cooling Accelero Xtreme Plus. Would like to know if there are other options like programs I could use to increase the stock fan speeds, maybe turn down the settings on the graphics card, upgrade case fans, etc. Would love some input/advice! Thanks
ASUS P7P55D-E LGA
i5 750 2.66GHz
PNY GTX 470
