GTX 480 PSU Help!!
Jaser1
11
I currently have a PSU with 700W, 2 +12v rails. Each rail is rated at 23A. The GTX 480 requires 42 amps on a +12v rail and uses a 6pin & 8 pin connector. Am I screwed as far as the PSU is concerned... Or... Could I hook the two separate rails (23amps each = 46 amps) into the separate pins to run the card?
I appreciate the help.
Thanks
lilotimz
875
if you want it to blow up and probably kill everything in your computer... Then yes go ahead and try it. Raidmax is synonymous with crap and unless they've improved over the last few years ( not to my knowledge ) then its still utter crap.
Switch it out for a brand name PSU with at least 50 amps on the 12v rails .
Jaser1
11
Then what is the point of having 2 +12v rails with only 23v each? Are the separate rails meant for SLI/Crossfire (run 1 card on each?)? If so, why are single rail PSUs with 50+amp rails considered SLI/Crossfire ready?
Thanks
