Will my 500w ThermalTake PSU enough to run my GTX 560 with no problems? I'm actually using it for a month now. And I haven't experienced anything bad yet happening to my computer. I just want to make sure if 500w is enough.
Well the recommended wattage for 560 is 520W, but as long as your PSU has 2x6pin and you are not running an extremely power hungry AMD cpu with overclocks, then you should be good.
Yep, that PSU will be quite sufficient.
You do not mention what other parts you have in your system and if you over clock or not though.
If you are overclocking, then you will need more power and the 500W will not be enough.
