Hi,
I have a GTX 1650 and GTX 590 installed in a Dell Alienware R3 mobo with an i7-2600 CPU and 4GB DDR3 RAM in dual channel configuration.
In order to be able to post & boot when the 1650 is installed, the 590 must be installed and plugged in as primary display to the monitor at time of pressing power button.
Otherwise, it freezes and fails to post, no display, OS corruption ect. Caused by (updated) crappy Dell BIOS refusing to work with Turing.
However, drivers for 1650 are installed and 590 is running on Microsoft basic drivers so after boot OS has lower resolution and looks crap.
When I take the signal cable out of the 590 and plug it into the 1650, image is proper and full resolution and works, but can’t use OS because trying to click on tabs/windows doesn’t display them on the 1650 output, just on the 590 output.
Any suggestions to fix this visual issue? Thank you
